LTE3680P SFP GPON OLT Transceiver
CLASS D 2488/1244 Mb/s
The LTE3680P is a low cost point to multi point (P2MP) Fiber to the Home, Business or Curb (FTTX) GPON OLT transceiver. It is designed for 2488Mb/s downstream / 1244Mb/s upstream duplex data links that employ high-speed burst mode TDM receivers/transmitters. It is based on the ITU-T G.984.2 Class D specifications for bidirectional communications over a single fiber and incorporates a high performance 1310nm Burst Mode APD/TIA receiver and 1490nm CW mode DFB transmitter. The Burst Signal Detect (BSD), the Burst Mode Receiver Reset (Rx_RESET), Transmit Disable (Tx_DIS), Transmit Fault (Tx_FAULT) and the interface monitor and control functions are LVTTL compatible. The industry standard 2x10 small form pluggable (SFP) package incorporates the SC/UPC receptacle. It is fabricated with a rugged die cast metal housing and cage assembly. Commercial range is available.
GPON OLT Class D | LTE3680P-BC+4 | SFP | SC/UPC | 20km | C | 6~10dBm | 2.488Gb/s | 1490nm | -33dBm | 1.244Gb/s | 1310nm |
• Access Networks
• Fiber to the Home, Curb, Office (FTTx)
• Point to Multi Point Service (P2MP)
• ITU-T G.984.2
• FSAN Class D
• Dual Wavelength Bidirectional Transceiver
• 2488Mb/s Downstream
• 1244Mb/s Upstream
• BER<10-10, 1244Mb/s, PRBS 223-1
• 1310nm APD/TIA Burst Mode Receiver
• 1490nm CW Mode DFB Laser
• ITU-T G.984.2 Complaint
• Single 3.3V DC supply
• Low Power Consumption
• 2x10 SFP Package Outline
• SC/UPC Optical Receptacle
