SFP28 25GSPON OLT Transceiver
The LTF6703 is intended for 25GSPON OLT in an SFP28 housing, which is based on the latest 25GSPON MSA. It is using an 1358nm 24.8832Gbps downstream transmitter and an 1260nm-1310nm upstream receiver working at 24.8832Gbps or 9.953Gbps. The transmitters can be controlled by the LVTTL Tx_DISABLE pin and the receivers incorporates the LVTTL Rx_LOS output.
The LTF6703 is designed to support up to 32 subscribers over distances of up to 20km in the ODN. It meets the EEC Directive 2015/863/EU for RoHS compliance
25GSPON OLT Class N2 | LTF6703-BCA+ | SFP28 | SC | 20km | C | 9dBm | 24.8832Gbps Gb/s | 1358nm | -26.3dBm -28dBm |
25.78125Gbps/ 24.8832Gbps |
1260~1310nm |
• 25GS-PON Access networks
• FTTH
• FTTB
• FTTC
• SFP28 Package
• 3.3V power supply
• 2 Lambda
• Single SC receptacle optical connector
• Hot pluggable
• 2x10 SFP28 Electrical Interface
