SFP28 25GS-PON ONU Transceiver
The LTF7605-BH+ is intended for 25GS-PON ONU transceiver in SFP28 housing , which is based on the latest 25GS-PON Specification V2.0. It is using a cooled 1300nm DML laser, which can support 25.781Gbps and 24.8832Gbps , working in burst mode and it is using an O-band 1358nm 24.8832Gbps downstream continuous receiver. The transmitter can be controlled by the LVTTL Tx_Burst function and the receiver incorporates the LVTTL Rx_LOS output.
The LTF7603-BH+ is designed to support up to 32 subscribers over distances of up to 20km in the ODN. It meets the EEC Directive 2015/863/EU for RoHS compliance.LTF7603-BH+ is default configured as a 25G/25G ONU.
25GSPON ONU | LTF7605-BH+ | SFP28 | SC/UPC | 20km | H | 4.78dBm | 25.78125/24.8832/ 9.953/10.3125Gb/s |
1300nm | -24.9dBm | 25.78125/24.8832Gb/s | 1358nm |
• 25GS-PON Access networks
• FTTH
• FTTB
• FTTC
• SFP28 Package
• 3.3V power supply
• 2 Lambda
• Single SC receptacle optical connector
• Hot pluggable
• 2x10 SFP28 Electrical Interface
