QSFP112 50GPON&XGSPON Combo PON OLT Transceiver
The LTQ5306-PC+ is a combination of 50GPON OLT and XGSPON OLT optical transceiver in an QSFP112 housing. The 50GPON bidirectional link is configured with 1300nm/1342nm optics and the XGSPON link is configured with 1270nm/1577nm optics. The 1270nm and 1300nm optical burst mode receivers incorporate APD/TIA optics for maximum sensitivity. The 50G transmitter incorporates a 1342nm EML laser assembly and the 10G transmitter incorporates a 1577nm EML laser assembly. The transmitters can be controlled by the LVTTL Tx_DISABLE function and the receivers incorporates the LVTTL Rx_SD output.
The LTQ5306-PC+ is designed to support up to 16 subscribers over distances of up to 5km, which is just for the 50GPON&XGSPON Combo OLT pre-DEMO experiment. It meets the EEC Directive 2015/863/EU for RoHS compliance.
50GPON&XGSPON Combo PON OLT | LTQ5306-PC+ | QSFP112 | SC | 20km | C | 2dBm~ 2~5dBm |
49.7664Gb/s 9.953Gb/s |
1340~1344nm 1575~1580nm |
-24.5dBm -26dBm |
24.8832 Gbp/s 9.953 Gb/s |
1290~1310nm 1260~1280nm |
• 50GPON&XGSPON Combo OLT DEMO Samples
• FTTH
• FTTB
• FTTC
• QSFP112 Package
• 3.3V DC power supply
• 4 Lambda
• SC/UPC receptacle optical connector
• Hot pluggable
• 2x19 QSFP112 Electrical Interface
• Refer to ITU-T G.9807.1
• Refer to ITU-T G.9804.3
