50GPON&10G EPON Combo OLT Transceiver
The LTQ5307-PC+ is a combination of 50GPON OLT and 10G EPON OLT optical transceiver in a QSFP-DD housing.The 50GPON bidirectional link is configured with 1342nm/1286nm optics, the 10G EPON link is configured with 1577nm/1270nm.The 1270nm and 1286nm optical burst mode receivers incorporate APD/TIA optics for maximum sensitivity. The 50G transmitter incorporates a 1342nm EML+SOA laser assembly, while the 10G transmitter incorporates a 1577nm EML laser assembly . The transmitters can be controlled by the LVTTL Tx_DISABLE function and the receivers incorporates the LVTTL Rx_SD output.
The LTQ5307-PC+ is designed to support up to 32 subscribers over distances of up to 20km, which is just for the 50GPON&10GEPON Combo OLT pre-DEMO experiment.
50GPON&10G EPON Combo OLT | LTQ5307-PC+ | QSFP-DD | SC | 20km | C | 5.5dBm 2~5dBm |
49.7664Gb/s 10.3125Gb/s |
1340~1344nm 1577nm |
-24.5dBm -28dBm |
24.8832 Gbp/s 10.3125Gb/s |
1286nm 1260~1280nm |
• 50GPON&10GEPON Combo OLT
• DEMO Samples
• FTTH
• FTTB
• FTTC
• QSFP-DD Package
• 3.3V DC power supply
• 4 Lambda
• SC/UPC receptacle optical connector
• Hot pluggable
• 4x19 QSFP-DD Electrical Interface
• Refer to ITU-T G.9804.3
• Refer to IEEE802.3av
