QSFP112 50G GPON ONU Transceiver
The LTQ3401-PC+ is intended for 50G GPON ONU DEMO in a QSFP112 housing. It is using a 1300nm 24.8832Gbps(can support 12.5Gbps) upstream burst transmitter which work in TDM configuration,and a 49.7664Gbps downstream continuous receiver.
The LTQ3401-PC+ is designed to support up to 16 subscribers over distances of up to 5km in the ODN ,which is just for the 50G GPON pre-DEMO experiment. It meets the EEC Directive 2015/863/EU for RoHS compliance.
50G GPON ONU LTQ3401-PC+ QSFP112 SC 20km C 2dBm~ 24.8832 Gb/s 1290nm~1310nm -21dBm 49.7664 Gb/s 1340nm~1344nm
  • 50G GPON ONU DEMO Samples
  • FTTH
  • FTTB
  • FTTC
  • QSFP112 Package
  • 3.3V power supply
  • 2 Lambda
  • Single SC receptacle optical connector
  • Hot pluggable
  • 2x19 QSFP112 Electrical Interface
