QSFP112 50G GPON ONU Transceiver
The LTQ3402-PC+ is intended for 50G GPON ONU DEMO in a QSFP112 housing. It is using a 1286nm 24.8832Gbps(can support 12.5Gbps) upstream burst transmitter which work in TDM configuration,and a 49.7664Gbps downstream continuous receiver.
The LTQ3402-PC+ is designed to support up to 16 subscribers over distances of up to 5km in the ODN ,which is just for the 50G GPON pre-DEMO experiment. It meets the EEC Directive 2015/863/EU for RoHS compliance.
50G GPON ONU | LTQ3402-PC+ | QSFP112 | SC | 20km | C | 2dBm | 24.8832 Gb/s | 1284nm~1288nm | -21dBm | 49.7664 Gb/s | 1340nm~1344nm |
• 50G GPON ONU DEMO Samples
• FTTH
• FTTB
• FTTC
• QSFP112 Package
• 3.3V power supply
• 2 Lambda
• Single SC receptacle optical connector
• Hot pluggable
• 2x19 QSFP112 Electrical Interface
