LMQ8811B QSFP-DD SR4.2 8 x26.56GBaud 850nm/908nm Transceiver
The LMQ8811B is a QSFP-DD Optical transceiver for 8 x 26.56GBaud optical links. It is compliant with the QSFP-DD MSA specifications. It operates at 26.56GBaud up to 100m over OM4 Multi-mode fiber.
LMQ8811B-PC+ | QSFP-DD | MPO | 100m | C | Multi-mode | 850nm 908nm |
8x50Gb/s | -6.5~4dBm(each lane) | -8.5~4dBm (each lane) |
• Data center
• 8x50 Gbps MMF optical interface
• Each electrical channel data rate up to 26.56GBaud with CDR
• Up to 100m link on OM4 Multi-mode Fiber
• 850nm/908nm VCSEL 850nm/908nm PD Array Technology
• QSFP-DD MSA HW Rev4.0 Compliance
• CMIS V4.0 Compliance
• MPO12 PC Optical Receptacle Type
• Monitors for VCSEL bias, transmitted power, received power, module temperature, and module power supply
• Case Operating Temperature: Commercial: 0 to 70ºC
• RoHS II Compliance
