LMQ8511B-PC+ QSFP28 BIDI Transceiver
850nm/908nm Transceiver
The LMQ8511B-PC+ is a QSFP28 Optical transceiver for 100Gbps interconnects . It is compliant with the QSFP28 MSA specifications. It operates at 25.78Gb/s up to 100m over OM4 Multi-mode fiber.
LMQ8511B-PC+ | QSFP28 | LC | 100m | C | Multi-mode | 850nm 908nm |
4x25Gb/s | -6.2~4dBm(each lane) | -8.2~4dBm (each lane) |
• Data Center
• QSFP28 MSA Specification Compliant, including new
functions per SFF-8636
• 100G Link Distances up to 70m over OM3, 100m over OM4
• Dual Wavelength VCSEL Bi-Directional Optical
Interface, PAM4 2x50Gbps 850nm/908nm
• Interface with Digital monitoring and maskable Interrupts for Expanded fuctionality
• Case Operating Temperature:
• Range 0 to 70ºC
• RoHS II Compliance
• Operating Mode: 4x25G NRZ to 2x50G PAM4
