DME8611A QSFP56 to QSFP56 AOC
200G to 2x100G Active Optical Cable
The DME8611A is a QSFP56 breakout active optical cable (AOC) for 4 x 26.56GBaud optical links. It is compliant with the QSFP56 MSA specifications. It operates at 26.56GBaud and the cable length is up to 100m.
DME8611A-QCXX | QSFP-DD/QSFP56 | Cable | 1~100m | C | Multi-mode | 850nm | 200Gb/s/2x100Gb/s | - | - |
High performance computing interconnect
Data center
4 independent parallel optical channels
Each channel data rate up to 26.56GBaud with integrated CDR
Hot Pluggable
Up to 100m link over OM4 Multi-mode
CML Compatible electrical I/O
QSFP56 MSA Compliance
SFF-8636 Compliance
Case Operating Temperature Range:
Commercial: 0 to 70ºC
RoHS compliance
