DMQ8611A QSFP56 to QSFP56 AOC
200G to 200G Active Optical Cable
The DMQ8611A is a QSFP56 analog solution active optical cable (AOC) for 4 x 26.56GBaud optical links. It is compliant with the QSFP56 MSA specifications. It operates at 26.56GBaud and the cable length is up to 100m .
DMQ8611A-QCXX | QSFP56 | Cable | 1~100m | C | Multi-mode | 850nm | 8x50Gb/s | - | - |
High performance computing interconnect
Data center
4 independent parallel optical channels
Each channel data rate up to 26.56GBaud with integrated CDR
Hot Pluggable
Up to 100m link over OM4 Multi-mode and 70m link over OM3 Multi-mode
CML Compatible electrical I/O
PAM4 & NRZ Compatible
Case Operating Temperature Range:
Commercial: 0 to 70ºC
RoHS II Compliance
Fiber Cable: Use OFNP Jacket (Aqua Colored Jacket)
QSFP56 MSA Compliance
SFF8636 or CMIS4.0 Compliance (Based on Customer Requirement)
