LMQ3928H-PC+ QSFP-DD LR4 Optical Transceiver
4x100G CWDM4 10km
The LMQ3928H-PC+ is a QSFP-DD Optical transceiver for 4x100Gb/s optical links. It meets the requirements of QSFP-DD MSA, operates from a 3.3V DC power supply and is offered in the commercial temperature range. The module has an aggregate link bandwidth in excess of 4x100Gb/s by multiplexing of 4 CWDM optical lanes, each lane capable of transmitting PAM4 53.125GBd over 10km on SMF optical fiber. It is fabricated with a rugged die cast metal housing and cage assembly. The device is Class I laser safety compliant and meets the EU Directive 2002/95/EC for RoHS compliance.
LMQ3928H-PC1 | QSFP-DD | LC | 10km | C | Single-mode | 1271nm 1291nm 1311nm 1331nm |
400Gb/s/4x100Gb/s | -2.7~5.1dBm | (-8.2+TECQ) dBm |
• 400G-LR4-10
• 400G-LR4-6
8 independent electrical input/output channels
CWDM4 wavelength
Dual LC optical connector
Hot Pluggable
10km link on SMF single-mode Fiber
cooled CWDM EML/ Pin PD Array
QSFP-DD MSA Compatible electrical I/O
Case Operating Temperature: 0 to 70ºC
+3.3V power supply
