![](/uploads/allimg/20230216/064ceca69d4a806a64533c9b1a1a55dd.png)
LTF7226B XGS-PON OLT Transceiver
Symmetrical 9.95328Gbps With Digital RSSI
The LTF7226B is intended for the XGS-PON OLT duplex optical transceiver module designed for low cost point-to-multipoint (P2MP) Fiber to the Home (FTTH), Business or Curb (FTTx) applications. It employs a 1577nm CW mode downlink EML operating at 9.953Gb/s and a 1270nm APD/TIA burst mode uplink receiver operating at 9.953Gbps and 2.488Gb/s. It is housed in a rugged die cast SFP+ package and is designed to operate over the commercial temperature, industrial temperature ranges. The transceiver requires a 3.3V power supply for operation. The laser transmitter can be controlled by the LVTTL Tx_Disable function, and the optical receiver incorporates LVTTL Rx_SD output.
It meets the EEC Directive 2015/863/EU for RoHS compliance. The Transceiver is ESD safe when tested according to IEC61000-4-2. The device complies with (US) FCC Class A, (Europe) CE Class A.
LTF7226B-BC+ LTF7226B-BH+ LTF7226B-BCA+ LTF7226B-BHA+ LTF7226B-BCB+ LTF7226B-BHB+ LTF7226B-BCC+ LTF7226B-BHC+ |
SFP+ | SC | 20km 40km 60km |
C, H | 2~5dBm 2~5dBm 4~7dBm 4~7dBm 6~9dBm 6~9dBm 8~11dBm 8~11dBm |
-26dBm -26dBm -28dBm -28dBm -30dBm -30dBm -32dBm -32dBm -27.5dBm -27.5dBm -29.5dBm -29.5dBm -31.5dBm -31.5dBm -33.5dBm -33.5dBm |
• Symmetric XGS-PON Access Networks
• Asymmetric XG-PON Access Networks
• Fiber to the Home
• Fiber to the Building
• Dual Wavelength Bidirectional Transceiver
Signal Fiber needed
2x10 SFP+ Die Cast Housing
SC Optical Interface
Single Fiber needed
SC/UPC Optical Interface
• Optical Transmitter
3.3V DC Power Supply
Low Power Consumption
9.953Gb/s Tx CW Mode Data Rate
1577nm CW Mode EML
• Optical Receiver
9.953Gb/s Rx Burst Mode Data Rate
2.488Gb/s Rx Burst Mode Data Rate
1270nm Burst Mode APD/TIA Receiver
Commercial: 0 to 70ºC
Industrial: -40 to 85ºC
• Monitor and Control Functions
Tx_DISABLE LVTTL
Tx_FAULT LVTTL
Rx_SD LVTTL
Rx_Reset LVTTL
Rate_Select LVTTL
Trigger for Digital RSSI LVTTL
I2C Serial Clock Input LVTTL
I2C Bidirectional Serial Data LVTTL
• RoHS Compliance
