LTF1503 SFP+ Optical transceiver
10G Ethernet 1550nm 8.5G to 10.5Gb/s 40km
The LTF1503 SFP+ transceiver is intended for 40km reach service from 8.5G to 10.5Gb/s 1550nm single mode high-speed communications equipment where low-cost, extraordinary performance and reliability are essential. It consumes low power, operates from a 3.3V DC power supply and is offered in the commercial temperature range. They are compliant with IEEE802.3ae 10GBASE-ER/EW , Fibre Channel,SFF-8431 and SFF-8432.
LTF1503-BC+
LTF1503-BH+
SFP+ LC 40km C,H Single-mode 1550nm 10Gb/s -4.7~4dBm -15.8dBm
• 10G BASE-ER/EW 10G Ethernet
•  8G Fibre Channel
•  LC Duplex optical interface
•  Maximum link length of 40km
•  8.5G to 10.5Gb/s
•  +3.3 V power supply
•  Low DC power consumption
• 2x10 SFP+ MSA compliant package
•  Hot swappable
•  High performance 1550nm EML laser
•  High sensitivity PIN/TIA optical receiver
• Single Mode operation
•  BER < 1X10-12
