LTF240XM SFP+ Tunable DWDM Optical Transceiver
C-band DWDM 8.5 to 11.09Gb/s 40 km
The LTF240X Tunable SFP+ module is a high performance tunable pluggable transceiver for use in the C-band window. The module is intended for 40km reach service from 8.5Gb/s to 11.09Gb/s high-speed telecommunications equipment where low-cost, extraordinary performance and reliability are essential. It consumes low power, operates from a 3.3V DC power supply and is offered in the commercial temperature range.  They are compliant with IEEE802.3ae 10GBASE-ER/EW , SFF-8431 and SFF-8432.
LTF240X-BC+ SFP+ LC 40km C Single-mode C-Band tunable DWDM 10Gb/s -3~3dBm -16dBm
• 10G BASE-ER/EW 10G Ethernet
•  8G Fibre Channel
•  LC Duplex optical interface
•  Maximum link length of 40km
•  8.5G to 10.5Gb/s
•  +3.3 V power supply
•  Low DC power consumption
• 2x10 SFP+ MSA compliant package
•  Hot swappable
•  High performance 1550nm EML laser
•  High sensitivity PIN/TIA optical receiver
• Single Mode operation
•  BER < 1X10-12
