LTF7226B XGS-PON OLT Transceiver Class E1 Symmetrical
9.95328Gbps
The LTF7226B is intended for the XGS-PON OLT duplex optical transceiver module designed for low cost point-to-multipoint (P2MP) Fiber to the Home (FTTH), Business or Curb (FTTx) applications. It employs a 1577nm CW mode downlink EML operating at 9.953Gb/s and a 1270nm APD/TIA burst mode uplink receiver operating at 9.953Gbps and 2.488Gb/s. It is housed in a rugged die cast SFP+ package and is designed to operate over the commercial temperature, industrial temperature ranges. The transceiver requires a 3.3V power supply for operation. The laser transmitter can be controlled by the LVTTL Tx_Disable function, and the optical receiver incorporates LVTTL Rx_SD output.
XGS-PON OLT Class E1 | LTF7226B-BCB+ LTF7226B-BHB+ |
SFP+ | SC/UPC | 20km | C, H | 6~9dBm | 9.953Gb/s | 1577nm | -30dBm -31.5dBm |
9.953Gb/s 2.488Gb/s |
1270nm |
• Symmetric XGS-PON Access Networks
• Asymmetric XG-PON Access Networks
• Fiber to the Home
• Fiber to the Building
• Dual Wavelength Bidirectional Transceiver
• Single Fiber needed
• 2x10 SFP+ Die Cast Housing
• SC/UPC Optical Interface
